[mapguide-trac] #1721: Resource user templates are not picked up if schema version > 1.0.0
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jun 15 07:20:20 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.2
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Due to a timing issue, the fetching and processing of user templates is
 done before the extended models addin can register validators and
 serializers for > 1.0.0 resources. Therefore templates using > 1.0.0
 resources fail to correctly load and are skipped during the loading
 process.
 The fix is to defer the processing of user templates to when the main
 Workbench has been initialized. At this point, all startup commands will
 have been executed and > 1.0.0 resources will have been registered.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1721>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
