[mapguide-trac] #138: Feature Labels of lines or polygons should have option to prevent being obscured.
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jun 24 11:11:12 EDT 2011
obscured.
 Reporter:  jng          |         Owner:
     Type:  enhancement  |        Status:  closed
 Priority:  medium       |     Milestone:
Component:  General      |       Version:
 Severity:  major        |    Resolution:  wontfix
 Keywords:               |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 This is both the limitation of the Layer Definition schema and label
 placement being at the mercy of the Renderer which is designed to only
 draw feature labels if it doesn't overlap with others.
 The centroid point workaround is the only proper way address this problem
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/138#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
