[mapguide-trac] #1631: Map Definition Editor Defects and Loose Ends
MapGuide Open Source trac_mapguide at osgeo.org
Tue May 3 02:32:41 EDT 2011
 Reporter:  jng      |         Owner:  jng
     Type:  defect   |        Status:  reopened
 Priority:  medium   |     Milestone:  Maestro-3.1
Component:  Maestro  |       Version:
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Description changed by jng:
Old description:
> The following defects were observed with the Map Definition Editor in
> Maestro 3.0 beta 1:
>  * ~~Deleting layers does not clear the layer editor~~
>  * ~~Deleting folders does not clear the folder editor~~
>  * ~~Dropping a Layer Definition into a Base Layer Group will not add it
> to the group, but rather creates a new base layer group instead.~~
>  * Drag/drop reordering of layers in a base layer group does nothing.
>  * ~~Drag/drop of an existing layer reference into a group ("Layers by
> Group" tab) does nothing.~~
>  * ~~It is possible for System.NullReferenceException to occur when
> adding the first layer to a Map Definition due to the fact that it
> naively assumes that obtaining the extents for the layer will always
> succeed.~~
>  * ~~Manual Scale List editor textbox does not allow the return
> keypress~~
>  * ~~Add a new validation rule: A map definition with 1 or more base
> layer groups, must have 1 or more finite scale ranges defined.~~
>  * ~~Editing the legend label incorrectly updates the layer display. This
> should be happening to the name component instead.~~
>  * ~~Allow deletion of elements by Del keypress~~
>  * The "Layers" section of the editor does not occupy the full vertical
> space provided.
New description:
 Maestro 3.0 beta 1:
  * ~~It is possible for System.NullReferenceException to occur when adding
 the first layer to a Map Definition due to the fact that it naively
 assumes that obtaining the extents for the layer will always succeed.~~
  * ~~Manual Scale List editor textbox does not allow the return keypress~~
  * ~~Add a new validation rule: A map definition with 1 or more base layer
 Observed with final release of Maestro 3.0:
 space provided.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1631#comment:9>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
