[mapguide-trac] #1684: MAPNAME parameter is not passed to initial task url on first load
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 9 11:24:29 EDT 2011
   Reporter:  jng          |       Owner:
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  AJAX Viewer  |     Version:  2.2.0
   Severity:  trivial      |    Keywords:
External_id:               |
 Load a weblayout with an initial task url.
 Inspect this url in the task pane. It contains the SESSION parameter, but
 not the MAPNAME parameter.
 Click the home button on the task pane and inspect the url again. It now
 contains both SESSION and MAPNAME parameters.
 In both initial and subsequent states, the page should be receiving the
 same SESSION and MAPNAME parameters.
 Observed with .net AJAX viewer. Need to confirm if PHP and Java exhibit
 the same problems.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1684>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
