[mapguide-trac] #1679: Extent not changing in RasterConfigurationDocument
MapGuide Open Source trac_mapguide at osgeo.org
Tue May 10 09:05:57 EDT 2011
   Reporter:  gBecker  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.0
  Component:  Maestro  |     Version:  2.2.0
   Severity:  major    |    Keywords:
External_id:           |
Comment(by jng):
 Can you build from source? If so, give r5770 a go.
 Note that if a default FDO extent [-10000000, 10000000] is encountered in
 one of the images, the calculated extent will most likely be the same.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1679#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
