[mapguide-trac] #1686: "auto" keyword changes syntax meaning in VS2010
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 11 02:21:47 EDT 2011
   Reporter:  ChristineBao  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:
  Component:  General       |     Version:  2.1.0
   Severity:  blocker       |    Keywords:
External_id:                |
Comment(by ChristineBao):
 There are two approaches to solve this problem:
 1. Remove "auto" keyword.[[BR]]
 "auto" keyword does not have special meaning in old C++, that is:
 [[BR]]
     auto        TK_Status       status = TK_Normal;
 [[BR]]
 is the same meaning as [[BR]]
 [[BR]]
 So the fixing is to remove "auto" keyword in
 $OS\Oem\DWFTK7.1\develop\global\build\VC 8.0\W3DToolkit\W3DToolkit.vcxproj
 code files, including both header file and code file. [[BR]]
 '''I will hold till tomorrow May 11th to start this removing, so if you
 have any suggestion, please reply to me as soon as possible!'''
 2. Remove "auto" keyword in VS2010 build only[[BR]]
 If there is reason to keep "auto" keyword, the fixing is to isolate non-
 VS2010 and VS2010 in such as way:[[BR]]
 //http://msdn.microsoft.com/en-us/library/b0084kay%28VS.80%29.aspx. Define
 for VS2010
 #if _MSC_VER >= 1600
 #elseif
 #endif
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1686#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
