[mapguide-trac] #740: GETSPATIALCONTEXTS and GDAL always returns default extents
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 11 23:45:56 EDT 2011
 Reporter:  crispinatime     |         Owner:
     Type:  defect           |        Status:  reopened
 Priority:  medium           |     Milestone:  2.2
Component:  Feature Service  |       Version:  2.2.0
 Severity:  critical         |    Resolution:
 Keywords:                   |   External_id:
Comment(by jng):
 I've attached a zip containing a custom built GDAL provider with a patch I
 made for FDO ticket 493 applied. This was built against FDO 3.5, meaning
 it will only work with a MGOS 2.2 install.
 Give this provider a spin and see if it solves the problem. My initial
 tests are promising. Rasters that previously returned default extents now
 returned the proper values.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/740#comment:11>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
