[mapguide-trac] #1690: SizeContext (Units) Edits Not Saved from Maestro
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 12 08:33:58 EDT 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  Maestro-3.0
  Component:  Maestro       |     Version:
   Severity:  major         |    Keywords:
External_id:                |
 I have just noticed that, despite the UI changing, the XML for the
 <SizeContext>MappingUnits</SizeContext> or
 <SizeContext>DeviceUnits</SizeContext> is not being changed on saving a
 layer resource.  Tested with linear feature type/layer.
 Current workaround is to revert to XML editor.
 PS - Add Maestro 3 to the trac ticket "Version" numbers
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1690>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
