[mapguide-trac] #1687: A DBXML exception happens under stress test
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 12 11:19:51 EDT 2011
 Reporter:  hubu              |         Owner:  hubu
     Type:  defect            |        Status:  closed
 Priority:  medium            |     Milestone:  2.3
Component:  Resource Service  |       Version:  2.2.0
 Severity:  critical          |    Resolution:  fixed
 Keywords:  DBXML             |   External_id:  1381089
Description changed by brucedechant:
Old description:
> After create about 150 sessions, MgServer can’t create session anymore.
> And we will get many errors like below:
>                 Error: An exception occurred in DB XML component.
>         Error: DB_RUNRECOVERY: Fatal error, run database recovery
> StackTrace:
>   - MgSiteServiceHandler.ProcessOperation() line 83 file
> SiteServiceHandler.cpp
>   - MgOpCreateSession.Execute() line 109 file OpCreateSession.cpp
>   - MgServerSiteService.CreateSession() line 762 file
> ServerSiteService.cpp
>   - MgServerResourceService.CreateRepository() line 541 file
> ServerResourceService.cpp
>   - MgSessionRepository.MgSessionRepository() line 76 file
> SessionRepository.cpp
> This is a regression since we implemented "File-per-Session". After
> create 150 sessions, the DBxml is locked(hang up), because it can’t
> allocate memory anymore.
> We need to tune DBXML configuration, reduce the log buffer and cache size
> for session repository.
New description:
 After create about 150 sessions, !MgServer can’t create session anymore.
 StackTrace:
 This is a regression since we implemented "File-per-Session". After create
 150 sessions, the DBxml is locked(hang up), because it can’t allocate
 memory anymore.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/1687#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
