[mapguide-trac] #1691: ODBC Editor: Allow user to choose built-in or 64-bit office drivers
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 12 21:45:58 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Currently the ODBC editor will only specify the 64-bit ODBC driver if it
 finds the user has chosen a file with the *.accdb or *.xlsx extension.
 This driver is required for MDB and XLS files if the MapGuide Server is
 64-bit. So the editor needs to be modified so the user can choose to use
 either the 32-bit or 64-bit ODBC driver.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1691>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
