[mapguide-trac] #1696: Drawing Source editor: When marking a DWF file, attempt to auto-set Coordinate System and extents
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 18 09:00:42 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 When loading DWFs via a Load Procedure the Coordinate System and Extents
 of the Drawing Source are set automatically. When you create these Drawing
 Sources manually, they are not. The Drawing Source editor should auto-set
 the coordinate system and extents when a DWF resource data file has been
 marked.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1696>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
