[mapguide-trac] #1679: Extent not changing in RasterConfigurationDocument
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 23 03:41:41 EDT 2011
   Reporter:  gBecker  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by gBecker):
 Extent is created but not correct!
 It's to late to do localization in GdalRasterItem.cs.
 I debugged the code and found out that you have to replace lines 302-305
 in CompositeFileCtrl.cs with the following lines:
 raster.MinX =
 Convert.ToDouble(scList.SpatialContext[0].Extent.LowerLeftCoordinate.X,
 System.Globalization.CultureInfo.InvariantCulture);
 raster.MinY =
 Convert.ToDouble(scList.SpatialContext[0].Extent.LowerLeftCoordinate.Y,
 raster.MaxX =
 Convert.ToDouble(scList.SpatialContext[0].Extent.UpperRightCoordinate.X,
 raster.MaxY =
 Convert.ToDouble(scList.SpatialContext[0].Extent.UpperRightCoordinate.Y,
 This fixes the issue.
 BTW the updated GDAL Provider dll doesn't work for me (MGOS 2.2
 final/64Bit). When trying to create a Raster-FeatureSource I get the
 message that the GdalProvider couldn't be loaded.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1679#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
