[mapguide-trac] #1631: Map Definition Editor Defects and Loose Ends
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 23 08:56:04 EDT 2011
 Reporter:  jng      |         Owner:  jng
     Type:  defect   |        Status:  reopened
 Priority:  medium   |     Milestone:  Maestro-3.1
Component:  Maestro  |       Version:
 Severity:  major    |    Resolution:
 Keywords:           |   External_id:
Description changed by jng:
Old description:
> The following defects were observed with the Map Definition Editor in
> Maestro 3.0 beta 1:
>  * ~~Deleting layers does not clear the layer editor~~
>  * ~~Deleting folders does not clear the folder editor~~
>  * ~~Dropping a Layer Definition into a Base Layer Group will not add it
> to the group, but rather creates a new base layer group instead.~~
>  * Drag/drop reordering of layers in a base layer group does nothing.
>  * ~~Drag/drop of an existing layer reference into a group ("Layers by
> Group" tab) does nothing.~~
>  * ~~It is possible for System.NullReferenceException to occur when
> adding the first layer to a Map Definition due to the fact that it
> naively assumes that obtaining the extents for the layer will always
> succeed.~~
>  * ~~Manual Scale List editor textbox does not allow the return
> keypress~~
>  * ~~Add a new validation rule: A map definition with 1 or more base
> layer groups, must have 1 or more finite scale ranges defined.~~
>  * ~~Editing the legend label incorrectly updates the layer display. This
> should be happening to the name component instead.~~
>  * ~~Allow deletion of elements by Del keypress~~
> Observed with final release of Maestro 3.0:
>  * The "Layers" section of the editor does not occupy the full vertical
> space provided.
>  * Cannot drag a child layout out from its parent group
>  * ~~Convert group to base layer group option is not implemented. Throws
> System.NotImplementedException~~
>  * Validate and guard against duplicate layer names
>  * Ensure that Base Layer Groups is only 1 level deep (ie. Cannot have a
> Base Layer Group within a Base Layer Group)
New description:
 Maestro 3.0 beta 1:
  * ~~Drag/drop reordering of layers in a base layer group does nothing.~~
  * ~~It is possible for System.NullReferenceException to occur when adding
 the first layer to a Map Definition due to the fact that it naively
 assumes that obtaining the extents for the layer will always succeed.~~
  * ~~Manual Scale List editor textbox does not allow the return keypress~~
  * ~~Add a new validation rule: A map definition with 1 or more base layer
 space provided.
  * ~~Cannot drag a child layout out from its parent group~~
  * ~~Ensure that Base Layer Groups is only 1 level deep (ie. Cannot have a
 Base Layer Group within a Base Layer Group)~~
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1631#comment:14>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
