[mapguide-trac] #1700: Error editing some existing ODBC feature sources
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 25 10:20:52 EDT 2011
   Reporter:  andrewd  |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-3.1
  Component:  Maestro  |     Version:  2.1.0
   Severity:  major    |    Keywords:
External_id:           |
 When I try to edit the schema of a particular ODBC feature source, I get
 an error in Maestro 3.1. I can edit the same feature source using
 2.1.4.5245 without problems. Other ODBC feature sources seem to work fine.
 Oddly enough, if I create a new feature source and point to the same
 problem dsn, I can successfully edit the schema.
 Here's the XML for the feature source (it's got a config file, but I'm not
 sure how to get at that in 3.1). Attached is a screen cap of the error.
 <?xml version="1.0" encoding="utf-8"?>
 <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:xsd="http://www.w3.org/2001/XMLSchema"
 xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
   <Provider>OSGeo.ODBC</Provider>
   <Parameter>
     <Name>DataSourceName</Name>
     <Value>petitcodiac_sections</Value>
   </Parameter>
   <Parameter>
     <Name>GenerateDefaultGeometryProperty</Name>
     <Value>false</Value>
   </Parameter>
   <ConfigurationDocument>config</ConfigurationDocument>
 </FeatureSource>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1700>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
