[mapguide-trac] #1701: Packages produced by Maestro may throw MgDecryptionException errors when loading
MapGuide Open Source trac_mapguide at osgeo.org
Wed May 25 22:30:29 EDT 2011
loading
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
 Packages produced by Maestro can fail to load with an
 MgDecryptionException being thrown.
 The current lead on this problem is that the server which I created the
 package from had a different Administrator password from the one which I
 was loading to, and my current theory is that the Maestro packaging logic
 is different from the MapGuide Server packaging logic with regards to
 resource security.
 I have the good and bad versions of these packages on hand. More
 investigation required.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1701>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
