[mapguide-trac] #1703: Use a more clearer error message for session keep alive if ping fails
MapGuide Open Source trac_mapguide at osgeo.org
Fri May 27 01:27:16 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-3.2
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Maestro uses a keep-alive timer to periodically ping the mapguide server
 to keep the session alive. Should the mapguide server go offline, you get
 a full ugly MgConnectionFailedException message.
 We know what this is, so this error should be cleaned up to be something
 more clearer like:
  "Failed to ping MapGuide Server. Perhaps it went offline. If it did,
 refresh the Site Explorer to create a new MapGuide session"
 or something to that effect.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1703>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
