[mapguide-trac] #1706: Maestro
MapGuide Open Source trac_mapguide at osgeo.org
Sun May 29 22:08:44 EDT 2011
#1706: Maestro
   Reporter:  ishka            |       Owner:
       Type:  defect           |      Status:  new
   Priority:  medium           |   Milestone:  Maestro-3.1
  Component:  Feature Service  |     Version:  2.2.0
   Severity:  major            |    Keywords:
External_id:                   |
 Adding unmanaged shapefiles dialog box displays only the folder level and
 not the file level. In order to add the shape files from the folder you
 actually need to add the folder first and then test the connection to make
 sure it works and add the file by name manually.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1706>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
