[mapguide-trac] #1768: Implement RFC110 UI
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 1 01:43:30 EDT 2011
   Reporter:  yangte  |       Owner:  Ted Yang
       Type:  task    |      Status:  new
   Priority:  high    |   Milestone:
  Component:  Server  |     Version:
   Severity:  major   |    Keywords:
External_id:          |
Comment(by yangte):
 The ProfilingAPI_GUI_Part6.patch is mainly fixed some UI defects:[[BR]]
 1. When session is timeout, the whole performance report page should
 redirect to the login page, not part of the page [[BR]]
 2. Some map needs a long time to execute the profiling map API, so we need
 to set the time limit longer for 15 minutes [[BR]]
 3. The column headers of the layers info table should be correct when the
 content is longer than the column width [[BR]]
 4. In IE9 quirks mode, the background div is display in the top, not cover
 the whole page, so change the position mode as "absolute"[[BR]]
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1768#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
