[mapguide-trac] #1863: schema report can't view latter class properties if there are two classes with same name
MapGuide Open Source trac_mapguide at osgeo.org
Tue Nov 22 01:30:18 EST 2011
with same name
   Reporter:  sparkliu  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  low       |   Milestone:
  Component:  General   |     Version:
   Severity:  trivial   |    Keywords:
External_id:            |
 1. Create a feature source which contains two same-name classes (under
 different schema).
 2. Try to use schema report to view schema of feature source. Two feature
 classes are in the list.
 3. Try to expand data properties of the second one. You'll find the data
 properties of first one is expanded instead.
 This is because the page only uses class name as ID so it will cause a
 problem when duplicate name exists. Fix uses schema ID as well.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1863>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
