[mapguide-trac] #1868: DataType inconsistency in LayerDefinition
MapGuide Open Source trac_mapguide at osgeo.org
Mon Nov 28 07:41:49 EST 2011
   Reporter:  gBecker  |       Owner:
       Type:  task     |      Status:  new
   Priority:  high     |   Milestone:  Maestro-4.0
  Component:  General  |     Version:  2.1.0
   Severity:  major    |    Keywords:
External_id:           |
Comment(by jng):
 The LayerDefinition schema messed up the original data type (see #985).
 As a result, the generated code also inherits this problem.
 As per the referenced ticket, the actual data type should be string.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1868#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
