[mapguide-trac] #1824: Calling CCoordinateSystemTransform::GetGeodeticTransformation() causes Assertion in debug mode and/or is prone to access violations
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 3 14:57:29 EDT 2011
   Reporter:  baertelchen  |       Owner:  baertelchen
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.3
  Component:  General      |     Version:  2.1.0
   Severity:  trivial      |    Keywords:  CoordinateSystem API MgCoordinateSystemTransform GetGeodeticTransformation NumberOfGeodeticTransformations
External_id:               |
 The code in CCoordinateSystemTransform::GetGeodeticTransformation() sets
 an emtpy wstring object to '\0' at index 0 what causes an assertion in
 debug mode.
 Not even that setting the string to "empty" is unnecessary, it's also
 prone to access violations in release builds.
 Also, the documentation says "...Returns a disposable pointer to the
 geodetic transformation definition indicated by the index parameter.  A
 null pointer is returned if the index parameter is zero..."
 Passing in 0 is absolutely valid, however.
 This ticket is about fixing 2 things:
 - the documentation of the methods [NumberOfGeodeticTransformations] and
 [GetGeodeticTransformation]
 - remove / fix the implementation of [GetGeodeticTransformation] so it
 least doesn't resets the empty string via the indexing parameter
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1824>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
