[mapguide-trac] #1827: Assertion in CCoordinateSystemMathComparator::SameCoordinateSystem is wrong
MapGuide Open Source trac_mapguide at osgeo.org
Mon Oct 10 05:24:23 EDT 2011
   Reporter:  baertelchen  |       Owner:  baertelchen
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:
  Component:  General      |     Version:  2.1.0
   Severity:  trivial      |    Keywords:  CoordinateSystem API CCoordinateSystemMathComparator SameCoordinateSystem
External_id:               |
 The assertion
 //If the units match, the unit scale matches.
 assert(FloatEqual(def1.unit_scl, def2.unit_scl, kdEpsilonScale));
 in the CCoordinateSystemMathComparator::SameCoordinateSystem might report
 a false-negativ error condition.
 CSMAP generates the unit_scl value from the ellipsoid / datum when an
 ellipsoid / datum is set via [CoordSys::SetEllipsoid / SetDatum] methods.
 When then comparing the resulting coordinate system objects, the
 ellipsoids are considered the same (by the math comparator) but the unit
 scales are not; at least not by the assert.
 For example, the library will cause the process to be terminated in debug
 builds for the following values:
 111321.448098 45299
 111321.448098 52280
 The assert should be removed as the code isn't doing anything with it
 anyway.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1827>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
