[mapguide-trac] #1796: MDF Model: Fix Memory Leak
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 1 14:19:38 EDT 2011
   Reporter:  gregboone         |       Owner:  gregboone
       Type:  defect            |      Status:  new
   Priority:  high              |   Milestone:  2.3
  Component:  Resource Service  |     Version:  2.2.0
   Severity:  major             |    Keywords:  Memory
External_id:                    |
 Fix a memory leak in the following function:
 void UnicodeString::WideCharToMultiByte(const wchar_t* uniChar, string&
 str)
 #ifdef _WIN32
     UTFCONVERT(UTF16,UTF8)
 #else
     UTFCONVERT(UTF32,UTF8)
 #endif
 In the macro defintion
 UTFCONVERT(FROMCHARSET,TOCHARSET)
 If you look at the macro defintion, you will see that if any of the
 methods that call this macro pass in a non-empty 'str' as the target, then
 the contents of that string will be overwritten without having free’d the
 previous content. This is due to the fact that the 'targetStart' pointer
 is directly extracted from the 'str' output parameter here:
 targetStart = (TOCHARSET*) str.c_str();\
 This causes full layer definition XML string leak (which can be a big
 string) per layer per graphics generation.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1796>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
