[mapguide-trac] #1797: XML edits to Drawing Sources are not persisted
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 2 01:55:58 EDT 2011
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:  Maestro-4.0
  Component:  Maestro  |     Version:
   Severity:  trivial  |    Keywords:
External_id:           |
 Open a Drawing Source in XML editor mode and manually change the extents.
 If you re-open the resource in XML mode, you'll see that the changes have
 not been applied
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1797>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
