[mapguide-trac] #1799: SizeContext (Units) Edits Not Saved from Maestro in Area layes
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 2 08:56:35 EDT 2011
   Reporter:  gabrimonfa  |       Owner:  jng
       Type:  defect      |      Status:  new
   Priority:  low         |   Milestone:
  Component:  Maestro     |     Version:
   Severity:  minor       |    Keywords:
External_id:              |
 Maestro 3.5 and trunk(rev.6112)
 The XML for SizeContext does not follow UI changes in Area layers.
 Moreover, the default value in UI is "DeviceUnits"  but saving it will
 results in MappingUnits in the XML.
 This bug seems very similar to #1690, and probably also the root cause
 (line 520 in AreaFeatureStyleEditor.cs is commented out)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1799>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
