[mapguide-trac] #1808: Duplicate Resource Doesn't Refresh Folder
MapGuide Open Source trac_mapguide at osgeo.org
Wed Sep 14 08:03:53 EDT 2011
   Reporter:  crispinatime  |       Owner:  jng
       Type:  defect        |      Status:  new
   Priority:  low           |   Milestone:  Maestro-4.0
  Component:  Maestro       |     Version:
   Severity:  minor         |    Keywords:
External_id:                |
 With Maesto 4b1, when you click on an item in a folder to duplicate the
 folder does not automatically refresh.
 If you hit the refresh button, it also doesn't refresh: this is possibly a
 different issues that when you have a resource in the folder selected and
 hit the refresh button the folder does not refresh - you need to select
 the parent folder currently for that to work.
 nce I realised that, I found the 7 duplicates I had created and thought
 had failed!
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1808>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
