[mapguide-trac] #1812: Maestro shp file load cause OutOfMemory Exception
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 19 00:53:48 EDT 2011
   Reporter:  captainst  |       Owner:  jng
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  Maestro-4.0
  Component:  Maestro    |     Version:  2.2.0
   Severity:  major      |    Keywords:  OutOfMemory
External_id:             |
Comment(by jng):
 3. Have you considered using aliases? You don't have to actually "load" a
 SHP file this way. Instead you copy the SHP file into a directory that has
 been set up as a MapGuide alias, and create a SHP feature source from that
 aliased path.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1812#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
