[mapguide-trac] #1812: Maestro shp file load cause OutOfMemory Exception
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 19 11:27:50 EDT 2011
 Reporter:  captainst    |         Owner:  jng
     Type:  defect       |        Status:  closed
 Priority:  medium       |     Milestone:  Maestro-4.0
Component:  Maestro      |       Version:  2.2.0
 Severity:  major        |    Resolution:  wontfix
 Keywords:  OutOfMemory  |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 I've had some thoughts about whether this "bug" is actually worth fixing,
 and I've come to the conclusion that it isn't.
 The simple reason is that uploading something as large as OSM SHP files
 that range in several hundreds of MB in size is not what I believe is the
 standard use case for Load Procedures.
 Aliases is a feature of MapGuide that is suited for this purpose and is
 something you should look at. Aliases can be created by using the MapGuide
 Site Administrator web application, or by editing serverconfig.ini in your
 MapGuide Server installation.
 Once you have created an alias, copy your OSM shape files into this
 aliased directory and create a SHP feature source that references this
 aliased path
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1812#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
