[mapguide-trac] #1813: RFC 94 Upgrade -- Add missing Geodetic API
MapGuide Open Source trac_mapguide at osgeo.org
Mon Sep 19 17:42:30 EDT 2011
   Reporter:  NormOlsen  |       Owner:  NormOlsen
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  2.3
  Component:  General    |     Version:  2.2.0
   Severity:  minor      |    Keywords:  Geodetic Path
External_id:             |
 It was recently discovered that the implementaion of RFC 94, completed a
 year ago, is missing a required API.  Specifically, an API which returns
 the name of the geodetic path definition used when a geodetic
 transformation was generated from an explicit geodetic path definition.
 The API is rather simple, simply return a STRING which contains the name
 of the definition which is now available in the !CsMap geodetic
 transformation definition structure.
 This API is needed to complete other development work.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1813>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
