[mapguide-trac] #1811: Maestro UI Does Not Respect Field/Property Use for Colours
MapGuide Open Source trac_mapguide at osgeo.org
Thu Sep 22 11:01:20 EDT 2011
 Reporter:  crispinatime  |         Owner:  jng
     Type:  defect        |        Status:  reopened
 Priority:  low           |     Milestone:  Maestro-4.0
Component:  Maestro       |       Version:
 Severity:  minor         |    Resolution:
 Keywords:                |   External_id:
Changes (by crispinatime):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Hmmm,
 OK - the issue now is that Maestro is great for advanced users but has
 maybe lost too much for the casual user.
 Now, if you have a specified colour it shows as the ARGB code - not so bad
 BUT importantly you have lost the UI for transparency and have to edit the
 first two characters in hex.  The old slider was obviously a better UI.
 I don't have the solution but want to raise the effect of this change on
 regular layers.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1811#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
