[mapguide-trac] #1815: Maestro does not find datasource from successful connection by Postgres FDO 3.5
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 23 12:00:04 EDT 2011
3.5
 Reporter:  captainst            |         Owner:  jng
     Type:  defect               |        Status:  closed
 Priority:  low                  |     Milestone:  Maestro-4.0
Component:  Maestro              |       Version:  2.2.0
 Severity:  major                |    Resolution:  wontfix
 Keywords:  FDO Postgis Maestro  |   External_id:
Comment(by jng):
 Note the Maestro will always try to preview data and layers at *full*
 extents. I would say 40s is par for the course, given that it is not
 normally expected to show a 300MB SHP at full scale and level of detail.
 This is where you then employ layer filters and scale ranges to reduce the
 level of detail and complexity at higher zoom levels, and you should then
 start to see improved rendering performance.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1815#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
