[mapguide-trac] #1816: filter problem with Maestro
MapGuide Open Source trac_mapguide at osgeo.org
Sun Sep 25 02:06:30 EDT 2011
   Reporter:  captainst  |       Owner:  jng
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  Maestro-4.0
  Component:  Maestro    |     Version:  2.2.0
   Severity:  trivial    |    Keywords:  Filter Layer Style
External_id:             |
 Thank you again Jack!
 I found out another strange phenomenon with Maestro, and I think of
 creating a new ticket with it.
 If I have understood correctly, I can add the "filter" in two places in
 Maestro:
 1st: add to "Filter" edit box in "Layer Settings"
 2nd: add with the Rules created with the ranges in "Layer Styles"
 I added in "Layer Styles" 3 rules, to show only the data with type
 "motorway", "motorway_link", "trunk", "primary", "primary_link". These are
 from OSM data. (shown in Fig1 attached).
 When I created a map with this layer and show in the browser, it took
 almost 40sec to show all. (shown in Fig2).
 However, if I add these rules to "Filter" edit box in "Layer Settings"
 (shown in Fig3), it took only 11sec to show all.
 So my impression is that the "filter" settings inside Layer Styles as
 shown in Fig1 does not work. Only the value in "Filter" edit box in "Layer
 Settings" works.
 Should it be a bug ?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1816>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
