[mapguide-trac] #1821: CCoordinateSystemCatalog does not re-evaluate library status if dictionary path is changed via SetDictionaryDir()
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 30 04:01:51 EDT 2011
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  low      |   Milestone:
  Component:  General  |     Version:  2.1.0
   Severity:  trivial  |    Keywords:
External_id:           |
 If you change the dictionary path in the Coordinate System Catalog, the
 library status is not updated. This means if the Coordinate System Catalog
 is initially failed (eg. a bad MENTOR_DICTIONARY_PATH value), then
 changing this dictionary path via SetDictionaryDir() does not update this
 library status.
 Attached is a patch that modifies SetDictionaryDir() to re-evaluate the
 library status
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1821>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
