[mapguide-trac] #1823: General Maestro 3.5 defects (editing of layers and layouts)
MapGuide Open Source trac_mapguide at osgeo.org
Fri Sep 30 07:30:22 EDT 2011
   Reporter:  janvw    |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:  Maestro-4.0
  Component:  Maestro  |     Version:
   Severity:  minor    |    Keywords:
External_id:           |
 1. In the Layout sections, under Commands, I can only change the
 properties (title, name) of custom commands. In earlier versions of
 Maestro I could change there also the properties of built-in commands.
 2. Also under Custom Commands, in the Advanced tab, when I click on
 "Search on this layer" I get the attached list instead of different layer
 names.
 3. Also in the Layout section, under Menus and Toolbars: The left pointing
 arrow in the middle (to add new commands to the toolbar/context menu/task
 menu) remains always grey.
 4. In the Layers sections, under Layer Properties Visible in Viewer, I
 cannot move properties up or down.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1823>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
