[mapguide-trac] #1977: Ubuntu 11.10 build fixes
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 2 12:31:07 EDT 2012
   Reporter:  jng           |       Owner:
       Type:  defect        |      Status:  new
   Priority:  high          |   Milestone:  2.4
  Component:  Build System  |     Version:
   Severity:  major         |    Keywords:
External_id:                |
Description changed by jng:
Old description:
> Attached is a patch that will make the MapGuide source tree buildable on
> Ubuntu 11.10. An overview of this patch is as follows:
New description:
 Ubuntu 11.10 with the provided compilers (GCC 4.6). An overview of this
  * `IMake/stdafx.h`: includes the cstdio header to fix compiler errors
 relating to stdio functions
  * `IMake/Makefile`: replace -mcpu (deprecated) with -mtune and replace
 i386 to i686. Also remove self deletion on "clean" target
  * `Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux.GNU`: Refined
 check for librt.so
  * `Oem/ACE/ACE_wrappers/include/makeinclude/platform_linux_common.GNU`:
 Refined check for librt.so
  * `Oem/geos-2.2.0/configure.in`: Fix invalid use of the AC_SUBST macro
 (on Ubuntu this spat out "AC_SUBST(xxx) is not a valid shell variable
 name" before this patch)
  * `Oem/SWIGEx/Makefile`: Same fixes as the Makefile for IMake
  * `Oem/dbxml/xqilla/Makefile.in`: Remove the lexer regeneration step as
 this requires a super-ancient (circa-1997) and custom-patched version of
 flex. Regenerating the lexer does not seem to be necessary
  * `Oem/dbxml/xqilla/include/xqilla/framework/XPath2MemoryManager.hpp`:
 includes the cstddef header to fix the "ptrdiff_t does not name a type"
 compiler error.
  * `Oem/Makefile.am`: Remove copy commands to non-existent DWF Toolkit
 files
  * `Common/Security/CryptographyUtil.cpp`: Include cstdio header to fix
 compiler errors.
  * `Common/Renderers/ObservationMesh.cpp`: include cstdio header to fix
 compiler errors.
  * `Common/Renderers/Makefile.am`: Add linker references to DWF Toolkit
  * `Common/Stylization/atom.h`: Rename Shape() to GetShape() to fix
 compiler error (declaration of 'virtual RichText::ATOM::Shape::Type
 RichText::ATOM::IStructure::Shape() const' changes meaning of 'Shape' from
 'class RichText::ATOM::Shape' [-fpermissive])
  * `Common/Stylization/atom_element_structure.h`: Rename Shape() to
 GetShape() to fix compiler error (declaration of 'virtual
 RichText::ATOM::Shape::Type RichText::ATOM::IStructure::Shape() const'
 changes meaning of 'Shape' from 'class RichText::ATOM::Shape'
 [-fpermissive])
  * `Common/Stylization/Makefile.am`: Add linker references to FDO
 Expression Engine
  * `Common/Stylization/SE_BufferPool.cpp`: Add cstdlib header to fix
 compiler errors.
  * `configure.in`: Update version to 2.4.0 and change -mcpu (deprecated)
 to -mtune and i386 to i686
 `Server/src/Gws/GwsQueryEngine/GwsBatchSortedBlockJoinQueryResults.cpp`:
 Include cstdio header to fix compiler errors.
  * `Web/src/CgiAgent/Makefile.am`: Add linker reference to
 MgMapGuideCommon and lib_json in oem
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1977#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
