[mapguide-trac] #1980: ODBC connection with MGOS 2.2: Faulty configuration document in Maestro 4?
MapGuide Open Source trac_mapguide at osgeo.org
Mon Apr 16 03:12:45 EDT 2012
   Reporter:  janvw    |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  medium   |   Milestone:
  Component:  Maestro  |     Version:
   Severity:  major    |    Keywords:
External_id:           |
Comment(by janvw):
 I tried to check out the 2.4 preview.
 I connected to the ODBC feature source in Maestro 4.0 (Test Connection was
 true). When trying to edit the schema for specifying the X/Y columns I get
 two errors:
 First a popup saying "The value is outside the expected range" and then a
 Maestro error message (see attached file).
 So I couldn't get to the point where Maestro is generating the
 configuration document.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1980#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
