[Mapguide-trac] [mapguide-trac] #2089: Maestro: InvokeURL Fusion widget incorrectly saving AdditionalParameter values
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 1 09:03:32 PDT 2012
values
   Reporter:  geomapper  |       Owner:  jng
       Type:  defect     |      Status:  new
   Priority:  high       |   Milestone:  Maestro-4.0-maintenance
  Component:  Maestro    |     Version:  2.2.0
   Severity:  major      |    Keywords:  maestro, fusion, invokeurl, additionalparameter
External_id:             |
 When trying to configure an InvokeURL widget in fusion with multiple
 AdditionalParameter objects, upon clicking "Save" the widget automatically
 overwrites the AdditionalParameter values with copies of the first
 AdditionalParameter.
 For example, when I configure the following InvokeURL widget in Maestro:
 <?xml version="1.0"?>
 <WidgetType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:type="UiWidgetType">
   <Name>Report Generator</Name>
   <Type>InvokeURL</Type>
   <Location />
   <Extension>
     <Url>http://localhost/Scripts/FormGenerator.php</Url>
     <DisableIfSelectionEmpty>true</DisableIfSelectionEmpty>
     <Target />
     <LayerSet>
           <Layer>Testlayer</Layer>
         </LayerSet>
     <AdditionalParameter>
           <Key>Selected</Key>
           <Value>$CurrentSelection</Value>
         </AdditionalParameter>
           <Key>DesiredField</Key>
           <Value>MASTERID</Value>
           <Key>LayerName</Key>
           <Value>TestLayer_Name</Value>
           <Key>URL</Key>
           <Value>http://localhost/TestFiles/reporttable.asp</Value>
           <Key>DestinationKeyName</Key>
   </Extension>
   <ImageUrl>images/icons.png</ImageUrl>
   <ImageClass>options</ImageClass>
   <Label>Report TEST</Label>
   <Tooltip>Report TEST</Tooltip>
   <StatusText>Report TEST</StatusText>
   <Disabled>false</Disabled>
 </WidgetType>
 Whenever I click "Save" the widget
 automatically changes itself to look like this:
   <Location />
   <Extension>
     <Target />
     <LayerSet>
     </LayerSet>
       <Key>Selected</Key>
       <Key>Selected</Key>
       <Key>Selected</Key>
       <Key>Selected</Key>
       <Key>Selected</Key>
   </Extension>
   <StatusText />
 </WidgetType>
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2089>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
