[Mapguide-trac] [mapguide-trac] #2090: QUERYMAPFEATURES does not support format=application/json
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 6 06:45:45 PDT 2012
   Reporter:  jng        |       Owner:
       Type:  defect     |      Status:  new
   Priority:  low        |   Milestone:  2.4
  Component:  Map Agent  |     Version:
   Severity:  trivial    |    Keywords:
External_id:             |
 The QUERYMAPFEATURES operation does not support application/json as an
 output format. It should support JSON output so that Fusion does not need
 to make redundant and unnecessary Xml2JSON.php calls
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2090>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
