[Mapguide-trac] [mapguide-trac] #2099: mg-desktop: Reduce excessive disk IO
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 21 23:44:32 PDT 2012
   Reporter:  jng          |       Owner:  jng
       Type:  defect       |      Status:  new
   Priority:  low          |   Milestone:  2.4
  Component:  Desktop API  |     Version:
   Severity:  minor        |    Keywords:
External_id:               |
 If you look at any process using mg-desktop in the Task Manager, chances
 are the "I/O Read Bytes" column will be through the roof.
 The explanation is simple, the mg-desktop implementation of
 MgResourceService is a simple wrapper around the file system, so every
 GetResourceContent() call (and Maestro does a lot of this) is a call to
 read a file from disk. Such calls add up real quick.
 The solution would be to have an in-memory cache of resource content, such
 that subsequent calls to GetResourceContent() on the same resource id
 returns a MgByteReader from a cached copy of the resource content.
 Subsequently, calls to SetResource() will flush existing entries out and
 update the cached entry.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2099>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
