[Mapguide-trac] [mapguide-trac] #2097: API documentation cleanup
MapGuide Open Source trac_mapguide at osgeo.org
Mon Aug 27 06:22:40 PDT 2012
   Reporter:  jng            |       Owner:  jng
       Type:  defect         |      Status:  new
   Priority:  low            |   Milestone:  2.4
  Component:  Documentation  |     Version:
   Severity:  trivial        |    Keywords:
External_id:                 |
Description changed by jng:
Old description:
> The current Web API documentation source does not cleanly build with  the
> version of doxygen that we're using (1.8.0).
> In addition, the documentation itself is missing in some parts
>  * Documentation of the WebApp classes (that are wrapped by the proxy
> classes in the the OSGeo.MapGuide.Web.dll assembly)
>  * Some internal classes are being leaked out. Need to compare with the
> exposed classes of the .net assemblies to determine which classes need to
> be hidden.
> ~~If you look at the generated Web API documentation for 2.4 and compare
> it to the "published" 2.0 version on mapguide.osgeo.org you can see there
> are some stark differences:
>  * The lack of a navigation tree
>  * The lack of a TOC
> The build process already warns about such issues, so something is
> definitely amiss here.~~
New description:
 be hidden.
 are some stark differences:~~
  * ~~The lack of a navigation tree~~
  * ~~The lack of a TOC~~
 ~~The build process already warns about such issues, so something is
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2097#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
