[Mapguide-trac] [mapguide-trac] #2102: MgDesktopSample can't run
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 28 00:13:48 PDT 2012
   Reporter:  bassonsh  |       Owner:
       Type:  task      |      Status:  new
   Priority:  medium    |   Milestone:  2.4
  Component:  General   |     Version:  2.4.0
   Severity:  minor     |    Keywords:  MgRenderingService could not be found
External_id:            |
 I've downloaded the MgDesktopSample source code and i'm trying to compile
 it on my PC but get some error saying that the 'MgRenderingService' could
 not be found.
 I've got some basic programming knowledge, i've followed the instructions
 in the readme.txt file that comes with the source code (changed the
 referenced assemblies to point to my mg-desktop location and update the
 post build command) and i still get these errors.
 I'm using visual studio 2010, i downloaded all 32bit files for this
 exercise and i'm working on a 64bit machine.
 I'm trying to play around with some code to edit the viewer (sample code)
 in such a way that i can just open any .mgp file and not just the default
 test package.
 I've attached a Word document to show the files that i downloaded for this
 and it also has a screenshot with the error.
 Any help would be greatly appreciated!
 Thank you very much.
 Regards,
 Shaun
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2102>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
