[Mapguide-trac] [mapguide-trac] #2102: MgDesktopSample can't run
MapGuide Open Source trac_mapguide at osgeo.org
Tue Aug 28 23:42:39 PDT 2012
   Reporter:  bassonsh     |       Owner:  jng
       Type:  task         |      Status:  new
   Priority:  medium       |   Milestone:  2.4
  Component:  Desktop API  |     Version:  2.4.0
   Severity:  minor        |    Keywords:  MgRenderingService could not be found
External_id:               |
Comment(by bassonsh):
 Thanks,
 I've tried that based on the classes being used in the previous lines on
 that page, but then the next line (see attached) is problematic as the
 MgDesktopMapViewerProvider class only takes one argument (map), which
 would then make the MgdRenderingService instance obsolete?
 Regards,
 Shaun
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2102#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
