[Mapguide-trac] [mapguide-trac] #2102: MgDesktopSample can't run
MapGuide Open Source trac_mapguide at osgeo.org
Wed Aug 29 01:47:49 PDT 2012
   Reporter:  bassonsh     |       Owner:  jng
       Type:  task         |      Status:  new
   Priority:  medium       |   Milestone:  2.4
  Component:  Desktop API  |     Version:  2.4.0
   Severity:  minor        |    Keywords:  MgRenderingService could not be found
External_id:               |
Comment(by bassonsh):
 I see, thanks. Thant would make sense.
 My project build succeeded now after fixing up that piece of code, but
 when i  run, i get the error below:
 Could not load file or assembly 'OSGeo.MapGuide.Desktop,
 Version=2.4.0.6914, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f' or
 one of its dependencies. The system cannot find the file specified.
 Is this just a case of version incompatibilities? I did fix the reference
 to that assembly with no errors. I took a screenshot of the properties of
 that assembly (attached).
 Thank you.
 Regards,
 Shaun
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2102#comment:5>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
