[Mapguide-trac] [mapguide-trac] #2102: MgDesktopSample can't run
MapGuide Open Source trac_mapguide at osgeo.org
Thu Aug 30 02:28:34 PDT 2012
   Reporter:  bassonsh     |       Owner:  jng
       Type:  task         |      Status:  new
   Priority:  medium       |   Milestone:  2.4
  Component:  Desktop API  |     Version:  2.4.0
   Severity:  minor        |    Keywords:  MgRenderingService could not be found
External_id:               |
Comment(by bassonsh):
 Ok just a bit of an update on my progress:
 With the help of some forums, i manage to solve the last error i reported
 by switching the  platform target in VS to x86. It kind of makes sense
 since i'm working with 32bit code on a 64bit machine. Now my code stops
 when i want to debug right in the beginning where it want to initialize
 the Platform.ini file. When i go down all the way the inner exception
 gives the following message:
 Unable to load DLL 'MapGuideDesktopUnmanagedApi': The specified module
 could not be found. (Exception from HRESULT: 0x8007007E)
 What i dont get is that the DLL is present in my referenced mg-desktop
 folder and i also cant add it as a reference. All errors are in the
 attached file (Error4).
 Any ideas?
 Thanks.
 Shaun
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2102#comment:8>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
