[Mapguide-trac] [mapguide-trac] #2196: TimedEventHandler Errors on Windows 7 Home Premium
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 4 10:47:25 PST 2012
   Reporter:  cgountanis  |       Owner:
       Type:  defect      |      Status:  new
   Priority:  high        |   Milestone:
  Component:  General     |     Version:  2.4.0
   Severity:  trivial     |    Keywords:  installer, mapguide, programdata
External_id:              |
 This post was updated on Dec 03, 2012; 9:48am.
 I am having issues with Windows 7 Home Premium on a tablet. Tried MG0S 2.2
 and 2.4 64bit. IIS is working, PHP is working, everything seems to be
 installed properly. MapAgent fails and the MapGuide IIS Worker Crash
 happens everytime when doing a repo list (Default screen in MapAgent).
 I logged in as Administrator and everything seems to install just fine.
 I tried switching from fastcgi to the MapAgent.exe on .fcgi calls and got
 a could not find C:\ProgramData\Autodesk cord system files. I copied those
 over from another machine and I still get IIS Worker crashes over and
 over.
 Is it possible to install on  Windows 7 Home Premium, some kind of tablet
 as well as the folders in Explorer have check boxes. I am telling you
 though, everything seems like it should work, installers are not giving
 errors, php.info works, IIS is working... really at a loss here.
 I checked every setting, seems like the installer is not doing things like
 installing the AUtodesk folder in C:\ProgramData\Autodesk... is this
 normal?
 Here is the base of the information and initial post: http://osgeo-
 org.1560.n6.nabble.com/Windows-7-Home-Premium-MapGuide-2-2-and-2-4
 -Testing-td5020395.html
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2196>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
