[Mapguide-trac] [mapguide-trac] #2198: ApplySchema does not take in class/schema deletions
MapGuide Open Source trac_mapguide at osgeo.org
Mon Dec 10 18:14:20 PST 2012
   Reporter:  jng      |       Owner:
       Type:  defect   |      Status:  new
   Priority:  high     |   Milestone:
  Component:  General  |     Version:  2.4.0
   Severity:  blocker  |    Keywords:
External_id:           |
 If you mark a schema or class definition as deleted and apply the changes
 through MgFeatureService::ApplySchema, the deletions do not occur.
 The problem is that for MgClassDefinition and MgFeatureSchema, the
 deletion flag is not persisted in the serialization/deserialization when
 it travels from the Web Tier to the Server Tier.
 This is why the server-only unit test for ApplySchema passes, but the
 attached PHP equivalent test fails.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/2198>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
