[Mapguide-trac] [mapguide-trac] #1367: GetSpatialContext always return same extent on FeatureSources
MapGuide Open Source trac_mapguide at osgeo.org
Tue Dec 18 03:14:23 PST 2012
 Reporter:  gBecker          |         Owner:
     Type:  enhancement      |        Status:  closed
 Priority:  low              |     Milestone:  2.5
Component:  Feature Service  |       Version:  2.1.0
 Severity:  minor            |    Resolution:  wontfix
 Keywords:                   |   External_id:
Changes (by jng):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Extent of the spatial context should not be used as an indicator of the
 minimum bounding box.
 Use either the SpatialExtents() aggregate function (where supported) or
 the special EXTENT() function (see:
 http://themapguyde.blogspot.com.au/2012/06/mapguides-undocumented-custom-
 aggregate.html)
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1367#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
