[mapguide-trac] #1944: when the map's layers are from different schemas, the features can't be selected
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 2 04:45:51 EST 2012
selected
   Reporter:  christinebao  |       Owner:  Christine Bao
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:
  Component:  Web API       |     Version:  2.1.0
   Severity:  trivial       |    Keywords:
External_id:  1447700       |
Comment(by christinebao):
 This defect is caused by the Map.cpp, void
 MgMap::BulkLoadIdentityProperties(MgFeatureService*
 featureService)funtion. It assumes that one feauture source only has one
 schema, so throws exception in this case.
 To fix it, the map structure should be modified and add a schema level.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1944#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
