[mapguide-trac] #1945: CCoordinateSystemTransform::Transform methods might return incorrect transformation results for geographic coordinate systems
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 2 16:18:01 EST 2012
   Reporter:  baertelchen  |       Owner:  baertelchen
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.4
  Component:  General      |     Version:
   Severity:  minor        |    Keywords:  coordinate system transformation transformation CCoordinateSystemTransform
External_id:               |
 The various [Transform] methods in the CCoordinateSystemTransform class
 trim input coordinates if the source coordinate system is geographic and
 the [IgnoreOutsideDomainWarning] flag is set.
 Mg API thus returns different values then CSMAP does. For example, running
 CSMAP's TEST.DAT file through the mg API isn't possible.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1945>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
