[mapguide-trac] #1948: Un-bufferable geometry in Sheboygan dataset
trac_mapguide at osgeo.org
Mon Feb 6 10:55:17 EST 2012
Reporter: jng | Owner:
Type: defect | Status: new
Priority: low | Milestone:
Component: General | Version: 2.2.0
Severity: trivial | Keywords:
External_id: |
1) Select the parcel in the attached screenshot (Autogenerated_SDF_ID =
8149)
2) Create a buffer from this selection with default settings
Expect: A buffer to be created around the selected feature
Got: The stock message for a C++ null pointer de-reference:
Problem:\nThe application encountered a problem and could not finish the
operation you just requested properly.\n\nSolution:\nIf it\'s the first
time you met this problem, try again or restart the application / session;
otherwise, describe the steps to reproduce this problem to the server
administrator for suggestions.
Modifying buffer.php to show the stack trace reveals it to be at:
- MgGeometry_Buffer() line 14619 file MgApi_wrap.cpp
Observed in the AJAX viewer (.net and PHP) in both MGOS 2.2 and trunk.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/1948>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
